BORUNTE BRTIRUS3050B
BORUNTE BRTIRUS3050B specs:
Type Industrial Robot
Brand BORUNTE
Model BRTIRUS3050B
Axes 7
Payload 500 kg
Reach 3050 mm
Repeatability 0.5 mm
Weight 3200 kg
Start programming BORUNTE BRTIRUS3050B
BORUNTE BRTIRUS3050B | SprutCAM X
BORUNTE BRTIRUS3050B description
Watch BORUNTE BRTIRUS3050B in 3D
BORUNTE BRTIRUS3050B applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot BORUNTE BRTIRUS3050B can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Continue reading to find out how BORUNTE BRTIRUS3050B can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
BORUNTE BRTIRUS3050B applications programmed with SprutCAM X Robot
How to start programming BORUNTE BRTIRUS3050B with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including BORUNTE. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the BORUNTE BRTIRUS3050B, please contact the manufacturer or local supplier.
If you have questions about purchasing the BORUNTE BRTIRUS3050B, please contact the manufacturer or local supplier.
