MOTOMAN GP400R
MOTOMAN GP400R specs:
Brand MOTOMAN
Model GP400R
Axes 7
Payload 400 kg
Reach 3518 mm
Repeatability 0.1 mm
Weight 3560 kg
Start programming MOTOMAN GP400R
MOTOMAN GP400R | SprutCAM X
MOTOMAN GP400R description
Watch MOTOMAN GP400R in 3D
MOTOMAN GP400R applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot MOTOMAN GP400R can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Trimming, Deburring, Grinding. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how MOTOMAN GP400R can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
MOTOMAN GP400R applications programmed with SprutCAM X Robot
How to start programming MOTOMAN GP400R with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including MOTOMAN. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the MOTOMAN GP400R, please contact the manufacturer or local supplier.
If you have questions about purchasing the MOTOMAN GP400R, please contact the manufacturer or local supplier.
