Toucan from the modeling to final result by robot milling
Toucan from the modeling to final result by robot milling | SprutCAM Xmaio 27, 2022
What does the project look like from the moment of modeling to the final result? nioform.se shows all the stages a project goes through to get the finished work.
“A few weeks ago I made toucans for the new playground at Lasse Åberg’s museum where Tor Svae and friends work. They will decorate the park a bit here and there, but now we have reused the drawing with some shape changes so that it can function as a feather swing!
This piece is made of 2 “pine and milled with a seat-friendly saddle shape. The bird will probably get handles and of course stylish colors before it is mounted on a coil spring in the park.
Extra grateful to be able to shape the models as I can simplify the production in the same step. Fun with wood, hope for more similar missions!”
“För några veckor sedan gjorde jag tukaner till den nya lekparken vid Lasse Åbergs museum som Tor Svae med vänner jobbar på. De kommer dekorera parken lite här och där men nu har vi återanvänt ritningen med några formändringar så att den kan fungera som fjädergunga!
Den här pjäsen är tillverkad i 2″ furu och fräst med en sittvänlig sadelform. Fågeln kommer sannolikt få handtag och naturligtvis stiliga färger innan den monteras på spiralfjäder i parken.
Extra tacksamt att få formbestämma modellerna då jag kan förenkla tillverkningen i samma moment. Kul med trä, hoppas på fler liknande uppdrag!”
Find more information abou SprutCAM X Robot statue machining here.
Compartilhe esta história
Obtenha uma versão de avaliação e comece a aprender on-line
Faça o download de uma versão de avaliação gratuita do SprutCAM X ou do SprutCAM X Robot para explorar os recursos do software. Faça cursos on-line para aprender SprutCAM X e obtenha um certificado após a conclusão.
