Jaka Zu 5
Jaka Zu 5 specs:
Type | Cobot |
Brand | Jaka |
Model | Zu 5 |
Axes | 6 |
Payload | 5 kg |
Reach | 954 mm |
Repeatability | 0.020 mm |
Weight | 23 kg |
Jaka Zu 5 description
Jaka Zu 5 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot Jaka Zu 5 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Continue reading to find out how Jaka Zu 5 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
![laptop Jaka Zu 5 | SprutCAM X](https://cdn.sprutcam.com/wp-content/uploads/2023/10/laptop.png)
Jaka Zu 5 applications programmed with SprutCAM X Robot
![Robot Milling Image of one of EVS QJR50-1A, QJAR series robot main applications programmed with SprutCAM X Robot CAD/CAM software](https://cdn.sprutcam.com/wp-content/uploads/2023/10/Robot-Milling.jpg)
![Hot Wire Image of one of EVS QJR50-1A, QJAR series robot main applications programmed with SprutCAM X Robot CAD/CAM software](https://cdn.sprutcam.com/wp-content/uploads/2023/10/Hot-Wire.jpg)
How to start programming Jaka Zu 5 with SprutCAM X Robot
