HANWHA HCR-14
HANWHA HCR-14 specs:
Type Cobot
Brand HANWHA
Model HCR-14
Axes 6
Payload 14 kg
Reach 1420 mm
Repeatability 0.04 mm
Weight 42 kg
Start programming HANWHA HCR-14
HANWHA HCR-14 | SprutCAM X
HANWHA HCR-14 description
Watch HANWHA HCR-14 in 3D
HANWHA HCR-14 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot HANWHA HCR-14 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Machine Tending, Pick and place, Assembly, Deburring, Polishing. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how HANWHA HCR-14 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
HANWHA HCR-14 applications programmed with SprutCAM X Robot
Polishing
How to start programming HANWHA HCR-14 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including HANWHA. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the HANWHA HCR-14, please contact the manufacturer or local supplier.
If you have questions about purchasing the HANWHA HCR-14, please contact the manufacturer or local supplier.
