HANWHA HCR 10L
HANWHA HCR 10L specs:
Type Cobot
Brand HANWHA
Model HCR 10L
Axes 6
Payload 10 kg
Reach 1800 mm
Repeatability 0.04 mm
Weight 45 kg
Start programming HANWHA HCR 10L
HANWHA HCR 10L | SprutCAM X
HANWHA HCR 10L description
Watch HANWHA HCR 10L in 3D
HANWHA HCR 10L applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot HANWHA HCR 10L can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Machine Tending, Pick and place, Assembly, Deburring, Polishing. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how HANWHA HCR 10L can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
HANWHA HCR 10L applications programmed with SprutCAM X Robot
Polishing
How to start programming HANWHA HCR 10L with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including HANWHA. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the HANWHA HCR 10L, please contact the manufacturer or local supplier.
If you have questions about purchasing the HANWHA HCR 10L, please contact the manufacturer or local supplier.
