KUKA iiwa 7 R800 - MF Inside elektrisch
KUKA iiwa 7 R800 - MF Inside elektrisch specs:
| Type | Cobot |
| Brand | KUKA |
| Model | iiwa 7 R800 - MF Inside elektrisch |
| Axes | 7 |
| Payload | 7 kg |
| Reach | 800 mm |
| Repeatability | 0.1 mm |
| Weight | 23.9 kg |
KUKA iiwa 7 R800 – MF Inside elektrisch description
KUKA iiwa 7 R800 – MF Inside elektrisch applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot KUKA iiwa 7 R800 - MF Inside elektrisch can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Pick and place, Assembly, Machine Tending, Polishing, Trimming.. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how KUKA iiwa 7 R800 – MF Inside elektrisch can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
KUKA iiwa 7 R800 – MF Inside elektrisch applications programmed with SprutCAM X Robot
Polishing
How to start programming KUKA iiwa 7 R800 - MF Inside elektrisch with SprutCAM X Robot
