IIMT CR5
IIMT CR5 specs:
Type Cobot
Brand IIMT
Model CR5
Axes 6
Payload 5 kg
Reach 1096 mm
Repeatability 0.02 mm
Weight 25 kg
Start programming IIMT CR5
IIMT CR5 | SprutCAM X
IIMT CR5 description
Watch IIMT CR5 in 3D
IIMT CR5 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot IIMT CR5 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Sculpture machining, Deburring, Grinding, Assembly. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how IIMT CR5 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
IIMT CR5 applications programmed with SprutCAM X Robot
Polishing
How to start programming IIMT CR5 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including IIMT. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the IIMT CR5, please contact the manufacturer or local supplier.
If you have questions about purchasing the IIMT CR5, please contact the manufacturer or local supplier.
