ESTUN ER130-3200
ESTUN ER130-3200 specs:
Type Industrial Robot
Brand ESTUN
Model ER130-3200
Axes 6
Payload 130 kg
Reach 3200 mm
Repeatability 0.06 mm
Weight 1120 kg
Start programming ESTUN ER130-3200
ESTUN ER130-3200 | SprutCAM X
ESTUN ER130-3200 description
Watch ESTUN ER130-3200 in 3D
ESTUN ER130-3200 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot ESTUN ER130-3200 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Trimming, Deburring, Machine Tending. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how ESTUN ER130-3200 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
ESTUN ER130-3200 applications programmed with SprutCAM X Robot
How to start programming ESTUN ER130-3200 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including ESTUN. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the ESTUN ER130-3200, please contact the manufacturer or local supplier.
If you have questions about purchasing the ESTUN ER130-3200, please contact the manufacturer or local supplier.
