ROKAE NB12-12/1.4
ROKAE NB12-12/1.4 specs:
Brand ROKAE
Model NB12-12/1.4
Payload 12 kg
Reach 1442 mm
Repeatability 0.03 mm
Weight 115 kg
Start programming ROKAE NB12-12/1.4
ROKAE NB12-12/1.4 | SprutCAM X
ROKAE NB12-12/1.4 description
Watch ROKAE NB12-12/1.4 in 3D
ROKAE NB12-12/1.4 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot ROKAE NB12-12/1.4 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Pick and place, Machine Tending, Robot welding, Painting, Dispensing. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how ROKAE NB12-12/1.4 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
ROKAE NB12-12/1.4 applications programmed with SprutCAM X Robot
Spraying
How to start programming ROKAE NB12-12/1.4 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including ROKAE. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the ROKAE NB12-12/1.4, please contact the manufacturer or local supplier.
If you have questions about purchasing the ROKAE NB12-12/1.4, please contact the manufacturer or local supplier.
