TECHMAN TM20S
TECHMAN TM20S specs:
| Type | Cobot |
| Brand | TECHMAN |
| Model | TM20S |
| Axes | 6 |
| Payload | 20 kg |
| Reach | 1300 mm |
| Repeatability | 0.03 mm |
| Weight | 33.3 kg |
TECHMAN TM20S description
TECHMAN TM20S applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot TECHMAN TM20S can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Trimming, Pick and place, Assembly.. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how TECHMAN TM20S can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
TECHMAN TM20S applications programmed with SprutCAM X Robot
How to start programming TECHMAN TM20S with SprutCAM X Robot
