STEP SD7-700
STEP SD7-700 specs:
Type Industrial Robot
Brand STEP
Model SD7-700
Axes 6
Payload 7 kg
Reach 723 mm
Repeatability 0.02 mm
Weight 33 kg
Start programming STEP SD7-700
STEP SD7-700 | SprutCAM X
STEP SD7-700 description
Watch STEP SD7-700 in 3D
STEP SD7-700 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot STEP SD7-700 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Continue reading to find out how STEP SD7-700 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
STEP SD7-700 applications programmed with SprutCAM X Robot
How to start programming STEP SD7-700 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including STEP. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the STEP SD7-700, please contact the manufacturer or local supplier.
If you have questions about purchasing the STEP SD7-700, please contact the manufacturer or local supplier.
