RAINBOW RB3-730ES(U-Version)
RAINBOW RB3-730ES(U-Version) specs:
Type Cobot
Brand RAINBOW
Model RB3-730ES(U-Version)
Axes 6
Payload 3 kg
Reach 730 mm
Repeatability 0.05 mm
Weight 11 kg
Start programming RAINBOW RB3-730ES(U-Version)
RAINBOW RB3-730ES(U-Version) | SprutCAM X
RAINBOW RB3-730ES(U-Version) description
Watch RAINBOW RB3-730ES(U-Version) in 3D
RAINBOW RB3-730ES(U-Version) applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot RAINBOW RB3-730ES(U-Version) can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Continue reading to find out how RAINBOW RB3-730ES(U-Version) can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
RAINBOW RB3-730ES(U-Version) applications programmed with SprutCAM X Robot
How to start programming RAINBOW RB3-730ES(U-Version) with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including RAINBOW. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the RAINBOW RB3-730ES(U-Version), please contact the manufacturer or local supplier.
If you have questions about purchasing the RAINBOW RB3-730ES(U-Version), please contact the manufacturer or local supplier.
