MOTOMAN NEX35
MOTOMAN NEX35 specs:
Type Industrial Robot
Brand MOTOMAN
Model NEX35
Axes 6
Payload 35 kg
Reach 2060 mm
Repeatability 0.04 mm
Weight 370 kg
Start programming MOTOMAN NEX35
MOTOMAN NEX35 | SprutCAM X
MOTOMAN NEX35 description
Watch MOTOMAN NEX35 in 3D
MOTOMAN NEX35 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot MOTOMAN NEX35 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Pick and place, Machine Tending, Assembly, Robot welding, Trimming. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how MOTOMAN NEX35 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
MOTOMAN NEX35 applications programmed with SprutCAM X Robot
How to start programming MOTOMAN NEX35 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including MOTOMAN. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the MOTOMAN NEX35, please contact the manufacturer or local supplier.
If you have questions about purchasing the MOTOMAN NEX35, please contact the manufacturer or local supplier.
