MOTOMAN HC30PL
MOTOMAN HC30PL specs:
Type Industrial Robot
Brand MOTOMAN
Model HC30PL
Axes 6
Payload 30 kg
Reach 1700 mm
Repeatability 0.05 mm
Weight 140 kg
Start programming MOTOMAN HC30PL
MOTOMAN HC30PL | SprutCAM X
MOTOMAN HC30PL description
Watch MOTOMAN HC30PL in 3D
MOTOMAN HC30PL applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot MOTOMAN HC30PL can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Machine Tending, Pick and place, Assembly, Deburring, Polishing. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how MOTOMAN HC30PL can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
MOTOMAN HC30PL applications programmed with SprutCAM X Robot
Polishing
How to start programming MOTOMAN HC30PL with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including MOTOMAN. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the MOTOMAN HC30PL, please contact the manufacturer or local supplier.
If you have questions about purchasing the MOTOMAN HC30PL, please contact the manufacturer or local supplier.
