MOTOMAN GP165R
MOTOMAN GP165R specs:
Type Industrial Robot
Brand MOTOMAN
Model GP165R
Axes 6
Payload 165 kg
Reach 3140 mm
Repeatability 0.05 mm
Weight 1760 kg
Start programming MOTOMAN GP165R
MOTOMAN GP165R | SprutCAM X
MOTOMAN GP165R description
Watch MOTOMAN GP165R in 3D
MOTOMAN GP165R applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot MOTOMAN GP165R can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Machine Tending, Pick and place, Assembly, Robot welding, Trimming. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how MOTOMAN GP165R can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
MOTOMAN GP165R applications programmed with SprutCAM X Robot
How to start programming MOTOMAN GP165R with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including MOTOMAN. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the MOTOMAN GP165R, please contact the manufacturer or local supplier.
If you have questions about purchasing the MOTOMAN GP165R, please contact the manufacturer or local supplier.
