KAWASAKI RS050N-B
KAWASAKI RS050N-B specs:
Type Industrial Robot
Brand KAWASAKI
Model RS050N-B
Axes 6
Payload 50 kg
Reach 2100 mm
Repeatability 0.07 mm
Weight 555 kg
Start programming KAWASAKI RS050N-B
KAWASAKI RS050N-B | SprutCAM X
KAWASAKI RS050N-B description
Watch KAWASAKI RS050N-B in 3D
KAWASAKI RS050N-B applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot KAWASAKI RS050N-B can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Pick and place, Assembly, Machine Tending, Dispensing, Deburring. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how KAWASAKI RS050N-B can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
KAWASAKI RS050N-B applications programmed with SprutCAM X Robot
Spraying
How to start programming KAWASAKI RS050N-B with SprutCAM X Robot
No, we are not in the business of selling robots. If you would like to purchase the KAWASAKI RS050N-B, please contact the manufacturer or local supplier.
If you have questions about purchasing the KAWASAKI RS050N-B, please contact the manufacturer or local supplier.
