KAWASAKI RS025N-A
KAWASAKI RS025N-A specs:
Type Industrial Robot
Brand KAWASAKI
Model RS025N-A
Axes 6
Payload 25 kg
Reach 1885 mm
Repeatability 0.04 mm
Weight 270 kg
Start programming KAWASAKI RS025N-A
KAWASAKI RS025N-A | SprutCAM X
KAWASAKI RS025N-A description
Watch KAWASAKI RS025N-A in 3D
KAWASAKI RS025N-A applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot KAWASAKI RS025N-A can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Pick and place, Assembly, Machine Tending, Dispensing, Deburring. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how KAWASAKI RS025N-A can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
KAWASAKI RS025N-A applications programmed with SprutCAM X Robot
Spraying
How to start programming KAWASAKI RS025N-A with SprutCAM X Robot
No, we are not in the business of selling robots. If you would like to purchase the KAWASAKI RS025N-A, please contact the manufacturer or local supplier.
If you have questions about purchasing the KAWASAKI RS025N-A, please contact the manufacturer or local supplier.
