JAKA Pro 5
JAKA Pro 5 specs:
Type Cobot
Brand JAKA
Model Pro 5
Axes 6
Payload 5 kg
Reach 954 mm
Repeatability 0.02 mm
Weight 23 kg
Start programming JAKA Pro 5
JAKA Pro 5 | SprutCAM X
JAKA Pro 5 description
Watch JAKA Pro 5 in 3D
JAKA Pro 5 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot JAKA Pro 5 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Robot welding, Pick and place, Assembly. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how JAKA Pro 5 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
JAKA Pro 5 applications programmed with SprutCAM X Robot
How to start programming JAKA Pro 5 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including JAKA. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the JAKA Pro 5, please contact the manufacturer or local supplier.
If you have questions about purchasing the JAKA Pro 5, please contact the manufacturer or local supplier.
