JAKA A 20
JAKA A 20 specs:
Type Cobot
Brand JAKA
Model A 20
Axes 6
Payload 20 kg
Reach 1780 mm
Repeatability 0.05 mm
Weight 68 kg
Start programming JAKA A 20
JAKA A 20 | SprutCAM X
JAKA A 20 description
Watch JAKA A 20 in 3D
JAKA A 20 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot JAKA A 20 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Deburring, Pick and place, Assembly. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how JAKA A 20 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
JAKA A 20 applications programmed with SprutCAM X Robot
How to start programming JAKA A 20 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including JAKA. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the JAKA A 20, please contact the manufacturer or local supplier.
If you have questions about purchasing the JAKA A 20, please contact the manufacturer or local supplier.
