Fanuc R-2000iC-165F
Fanuc R-2000iC-165F specs:
| Type | |
| Brand | |
| Model | |
| Axes | |
| Payload | |
| Reach | |
| Repeatability | |
| Weight |
Fanuc R-2000iC-165F description
Fanuc R-2000iC-165F applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot Fanuc R-2000iC-165F can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Continue reading to find out how Fanuc R-2000iC-165F can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
Fanuc R-2000iC-165F applications programmed with SprutCAM X Robot
How to start programming Fanuc R-2000iC-165F with SprutCAM X Robot
