EPSON C3-A601CT
EPSON C3-A601CT specs:
Type Industrial Robot
Brand EPSON
Model C3-A601CT
Axes 6
Payload 3 kg
Reach 600 mm
Repeatability 0.02 mm
Weight 27 kg
Start programming EPSON C3-A601CT
EPSON C3-A601CT | SprutCAM X
EPSON C3-A601CT description
Watch EPSON C3-A601CT in 3D
EPSON C3-A601CT applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot EPSON C3-A601CT can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Trimming, Deburring, Pick and place. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how EPSON C3-A601CT can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
EPSON C3-A601CT applications programmed with SprutCAM X Robot
How to start programming EPSON C3-A601CT with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including EPSON. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the EPSON C3-A601CT, please contact the manufacturer or local supplier.
If you have questions about purchasing the EPSON C3-A601CT, please contact the manufacturer or local supplier.
