CRP RH18-06-W
CRP RH18-06-W specs:
| Type | Industrial Robot |
| Brand | CRP |
| Model | RH18-06-W |
| Axes | 6 |
| Payload | 6 kg |
| Reach | 1850 mm |
| Repeatability | 0.08 mm |
| Weight | 170 kg |
CRP RH18-06-W description
CRP RH18-06-W applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot CRP RH18-06-W can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Sculpture machining, Deburring, Additive manufacturing.. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how CRP RH18-06-W can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
CRP RH18-06-W applications programmed with SprutCAM X Robot
How to start programming CRP RH18-06-W with SprutCAM X Robot
