CRP RA27-50-SR
CRP RA27-50-SR specs:
Type Industrial Robot
Brand CRP
Model RA27-50-SR
Axes 6
Payload 50 kg
Reach 2680 mm
Repeatability 0.08 mm
Weight 728 kg
Start programming CRP RA27-50-SR
CRP RA27-50-SR | SprutCAM X
CRP RA27-50-SR description
Watch CRP RA27-50-SR in 3D
CRP RA27-50-SR applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot CRP RA27-50-SR can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Continue reading to find out how CRP RA27-50-SR can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
CRP RA27-50-SR applications programmed with SprutCAM X Robot
Polishing
How to start programming CRP RA27-50-SR with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including CRP. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the CRP RA27-50-SR, please contact the manufacturer or local supplier.
If you have questions about purchasing the CRP RA27-50-SR, please contact the manufacturer or local supplier.
