AUTONOX AT-00028
AUTONOX AT-00028 specs:
Type Industrial Robot
Brand AUTONOX
Model AT-00028
Axes 6
Payload
Reach
Repeatability
Weight
Start programming AUTONOX AT-00028
AUTONOX AT-00028 | SprutCAM X
AUTONOX AT-00028 description
Watch AUTONOX AT-00028 in 3D
AUTONOX AT-00028 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot AUTONOX AT-00028 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Robot welding, Assembly, Machine Tending.. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how AUTONOX AT-00028 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
AUTONOX AT-00028 applications programmed with SprutCAM X Robot
How to start programming AUTONOX AT-00028 with SprutCAM X Robot
No, we are not in the business of selling robots. If you would like to purchase the AUTONOX AT-00028, please contact the manufacturer or local supplier.
If you have questions about purchasing the AUTONOX AT-00028, please contact the manufacturer or local supplier.
