DOBOT CR12
DOBOT CR12 specs:
Brand DOBOT
Model CR12
Payload 12 kg
Reach 1425 mm
Repeatability 0.03 mm
Weight 39.5 kg
Start programming DOBOT CR12
DOBOT CR12 | SprutCAM X
DOBOT CR12 description
Watch DOBOT CR12 in 3D
DOBOT CR12 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot DOBOT CR12 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Sculpture machining, Multiaxis cutting, Pick and place, Assembly.. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how DOBOT CR12 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
DOBOT CR12 applications programmed with SprutCAM X Robot
How to start programming DOBOT CR12 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including DOBOT. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the DOBOT CR12, please contact the manufacturer or local supplier.
If you have questions about purchasing the DOBOT CR12, please contact the manufacturer or local supplier.
