ROKAE xMate CR12
ROKAE xMate CR12 specs:
| Type | Cobot |
| Brand | ROKAE |
| Model | xMate CR12 |
| Axes | 6 |
| Payload | 12 kg |
| Reach | 1434 mm |
| Repeatability | 0.03 mm |
| Weight | 43 kg |
ROKAE xMate CR12 description
ROKAE xMate CR12 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot ROKAE xMate CR12 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Trimming, Deburring, Assembly. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how ROKAE xMate CR12 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
ROKAE xMate CR12 applications programmed with SprutCAM X Robot
How to start programming ROKAE xMate CR12 with SprutCAM X Robot
