OMRON TM5M-700 SEMI
OMRON TM5M-700 SEMI specs:
Type Cobot
Brand OMRON
Model TM5M-700 SEMI
Axes 6
Payload
Reach
Repeatability
Weight
Start programming OMRON TM5M-700 SEMI
OMRON TM5M-700 SEMI | SprutCAM X
OMRON TM5M-700 SEMI description
Watch OMRON TM5M-700 SEMI in 3D
OMRON TM5M-700 SEMI applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot OMRON TM5M-700 SEMI can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Deburring, Pick and place, Assembly. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how OMRON TM5M-700 SEMI can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
OMRON TM5M-700 SEMI applications programmed with SprutCAM X Robot
How to start programming OMRON TM5M-700 SEMI with SprutCAM X Robot
No, we are not in the business of selling robots. If you would like to purchase the OMRON TM5M-700 SEMI, please contact the manufacturer or local supplier.
If you have questions about purchasing the OMRON TM5M-700 SEMI, please contact the manufacturer or local supplier.
