OMRON TM14X
OMRON TM14X specs:
Type Cobot
Brand OMRON
Model TM14X
Axes 6
Payload 14 kg
Reach 1100 mm
Repeatability 0.1 mm
Weight 32.5 kg
Start programming OMRON TM14X
OMRON TM14X | SprutCAM X
OMRON TM14X description
Watch OMRON TM14X in 3D
OMRON TM14X applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot OMRON TM14X can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Trimming, Deburring, Pick and place, Assembly.. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how OMRON TM14X can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
OMRON TM14X applications programmed with SprutCAM X Robot
How to start programming OMRON TM14X with SprutCAM X Robot
No, we are not in the business of selling robots. If you would like to purchase the OMRON TM14X, please contact the manufacturer or local supplier.
If you have questions about purchasing the OMRON TM14X, please contact the manufacturer or local supplier.
