OMRON RT6-1101324
OMRON RT6-1101324 specs:
| Type | Cobot |
| Brand | OMRON |
| Model | RT6-1101324 |
| Axes | 6 |
| Payload | 12 kg |
| Reach | 1300 mm |
| Repeatability | 0.03 mm |
| Weight | 33.3 kg |
OMRON RT6-1101324 description
OMRON RT6-1101324 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot OMRON RT6-1101324 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Pick and place, Assembly, Machine Tending. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how OMRON RT6-1101324 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
OMRON RT6-1101324 applications programmed with SprutCAM X Robot
How to start programming OMRON RT6-1101324 with SprutCAM X Robot
