MOTOMAN HD10DT
MOTOMAN HD10DT specs:
Type Industrial Robot
Brand MOTOMAN
Model HD10DT
Axes 6
Payload 10 kg
Reach 1379 mm
Repeatability 0.05 mm
Weight 58 kg
Start programming MOTOMAN HD10DT
MOTOMAN HD10DT | SprutCAM X
MOTOMAN HD10DT description
Watch MOTOMAN HD10DT in 3D
MOTOMAN HD10DT applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot MOTOMAN HD10DT can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Trimming, Deburring, Multiaxis cutting, Machine Tending, Pick and place. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how MOTOMAN HD10DT can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
MOTOMAN HD10DT applications programmed with SprutCAM X Robot
How to start programming MOTOMAN HD10DT with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including MOTOMAN. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the MOTOMAN HD10DT, please contact the manufacturer or local supplier.
If you have questions about purchasing the MOTOMAN HD10DT, please contact the manufacturer or local supplier.
