MOTOMAN HC30PL
MOTOMAN HC30PL specs:
| Type | Industrial Robot |
| Brand | MOTOMAN |
| Model | HC30PL |
| Axes | 6 |
| Payload | 30 kg |
| Reach | 1700 mm |
| Repeatability | 0.05 mm |
| Weight | 140 kg |
MOTOMAN HC30PL description
MOTOMAN HC30PL applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot MOTOMAN HC30PL can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Machine Tending, Pick and place, Assembly, Deburring, Polishing. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how MOTOMAN HC30PL can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
MOTOMAN HC30PL applications programmed with SprutCAM X Robot
Polishing
How to start programming MOTOMAN HC30PL with SprutCAM X Robot
