KUKA KR 140 L200 comp
KUKA KR 140 L200 comp specs:
Type Industrial Robot
Brand KUKA
Model KR 140 L200 comp
Axes 6
Payload 140 kg
Reach 2400 mm
Repeatability 0.15 mm
Weight 540 kg
Start programming KUKA KR 140 L200 comp
KUKA KR 140 L200 comp | SprutCAM X
KUKA KR 140 L200 comp description
Watch KUKA KR 140 L200 comp in 3D
KUKA KR 140 L200 comp applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot KUKA KR 140 L200 comp can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Machine Tending, Robot welding, Pick and place, Deburring, Trimming. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how KUKA KR 140 L200 comp can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
KUKA KR 140 L200 comp applications programmed with SprutCAM X Robot
How to start programming KUKA KR 140 L200 comp with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including KUKA. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the KUKA KR 140 L200 comp, please contact the manufacturer or local supplier.
If you have questions about purchasing the KUKA KR 140 L200 comp, please contact the manufacturer or local supplier.
