KUKA iiwa7 R800 - Basis-Flansch
KUKA iiwa7 R800 - Basis-Flansch specs:
| Type | Cobot |
| Brand | KUKA |
| Model | iiwa7 R800 - Basis-Flansch |
| Axes | 7 |
| Payload | 7 kg |
| Reach | 800 mm |
| Repeatability | 0.1 mm |
| Weight | 23.9 kg |
KUKA iiwa7 R800 – Basis-Flansch description
KUKA iiwa7 R800 – Basis-Flansch applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot KUKA iiwa7 R800 - Basis-Flansch can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Assembly, Machine Tending, Pick and place.. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how KUKA iiwa7 R800 – Basis-Flansch can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
KUKA iiwa7 R800 – Basis-Flansch applications programmed with SprutCAM X Robot
How to start programming KUKA iiwa7 R800 - Basis-Flansch with SprutCAM X Robot
