KAWASAKI RA020N-A
KAWASAKI RA020N-A specs:
Type Industrial Robot
Brand KAWASAKI
Model RA020N-A
Axes 6
Payload 20 kg
Reach 1725 mm
Repeatability 0.04 mm
Weight 230 kg
Start programming KAWASAKI RA020N-A
KAWASAKI RA020N-A | SprutCAM X
KAWASAKI RA020N-A description
Watch KAWASAKI RA020N-A in 3D
KAWASAKI RA020N-A applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot KAWASAKI RA020N-A can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Continue reading to find out how KAWASAKI RA020N-A can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
KAWASAKI RA020N-A applications programmed with SprutCAM X Robot
Polishing
How to start programming KAWASAKI RA020N-A with SprutCAM X Robot
No, we are not in the business of selling robots. If you would like to purchase the KAWASAKI RA020N-A, please contact the manufacturer or local supplier.
If you have questions about purchasing the KAWASAKI RA020N-A, please contact the manufacturer or local supplier.
