KAWASAKI BXP110L
KAWASAKI BXP110L specs:
Type Industrial Robot
Brand KAWASAKI
Model BXP110L
Axes 6
Payload 110 kg
Reach 2597 mm
Repeatability 0,06 mm
Weight 870 kg
Start programming KAWASAKI BXP110L
KAWASAKI BXP110L | SprutCAM X
KAWASAKI BXP110L description
Watch KAWASAKI BXP110L in 3D
KAWASAKI BXP110L applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot KAWASAKI BXP110L can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Continue reading to find out how KAWASAKI BXP110L can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
KAWASAKI BXP110L applications programmed with SprutCAM X Robot
How to start programming KAWASAKI BXP110L with SprutCAM X Robot
No, we are not in the business of selling robots. If you would like to purchase the KAWASAKI BXP110L, please contact the manufacturer or local supplier.
If you have questions about purchasing the KAWASAKI BXP110L, please contact the manufacturer or local supplier.
