INOVANCE IR-R25-178S5
INOVANCE IR-R25-178S5 specs:
Type Industrial Robot
Brand INOVANCE
Model IR-R25-178S5
Axes 6
Payload 25 kg
Reach 1783 mm
Repeatability 0.03 mm
Weight 255 kg
Start programming INOVANCE IR-R25-178S5
INOVANCE IR-R25-178S5 | SprutCAM X
INOVANCE IR-R25-178S5 description
Watch INOVANCE IR-R25-178S5 in 3D
INOVANCE IR-R25-178S5 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot INOVANCE IR-R25-178S5 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Machine Tending, Pick and place, Assembly, Robot welding, Painting. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how INOVANCE IR-R25-178S5 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
INOVANCE IR-R25-178S5 applications programmed with SprutCAM X Robot
Spraying
How to start programming INOVANCE IR-R25-178S5 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including INOVANCE. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the INOVANCE IR-R25-178S5, please contact the manufacturer or local supplier.
If you have questions about purchasing the INOVANCE IR-R25-178S5, please contact the manufacturer or local supplier.
