HSR JH620-1800
HSR JH620-1800 specs:
Type Industrial Robot
Brand HSR
Model JH620-1800
Axes 6
Payload 20 kg
Reach 1800 mm
Repeatability 0.05 mm
Weight 280 kg
Start programming HSR JH620-1800
HSR JH620-1800 | SprutCAM X
HSR JH620-1800 description
Watch HSR JH620-1800 in 3D
HSR JH620-1800 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot HSR JH620-1800 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Continue reading to find out how HSR JH620-1800 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
HSR JH620-1800 applications programmed with SprutCAM X Robot
How to start programming HSR JH620-1800 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including HSR. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the HSR JH620-1800, please contact the manufacturer or local supplier.
If you have questions about purchasing the HSR JH620-1800, please contact the manufacturer or local supplier.
