EPSON C12-B1401C
EPSON C12-B1401C specs:
Type Industrial Robot
Brand EPSON
Model C12-B1401C
Axes 6
Payload 12 kg
Reach 1400 mm
Repeatability 0.05 mm
Weight 62 kg
Start programming EPSON C12-B1401C
EPSON C12-B1401C | SprutCAM X
EPSON C12-B1401C description
Watch EPSON C12-B1401C in 3D
EPSON C12-B1401C applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot EPSON C12-B1401C can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Trimming, Deburring, Pick and place. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how EPSON C12-B1401C can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
EPSON C12-B1401C applications programmed with SprutCAM X Robot
How to start programming EPSON C12-B1401C with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including EPSON. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the EPSON C12-B1401C, please contact the manufacturer or local supplier.
If you have questions about purchasing the EPSON C12-B1401C, please contact the manufacturer or local supplier.
