DOBOT CR5A
DOBOT CR5A specs:
Type Cobot
Brand DOBOT
Model CR5A
Axes 6
Payload
Reach
Repeatability
Weight
Start programming DOBOT CR5A
DOBOT CR5A | SprutCAM X
DOBOT CR5A description
Watch DOBOT CR5A in 3D
DOBOT CR5A applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot DOBOT CR5A can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Pick and place, Assembly, Machine Tending. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how DOBOT CR5A can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
DOBOT CR5A applications programmed with SprutCAM X Robot
How to start programming DOBOT CR5A with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including DOBOT. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the DOBOT CR5A, please contact the manufacturer or local supplier.
If you have questions about purchasing the DOBOT CR5A, please contact the manufacturer or local supplier.
