BORUNTE BRTIRUS3030A
BORUNTE BRTIRUS3030A specs:
Type Industrial Robot
Brand BORUNTE
Model BRTIRUS3030A
Axes 6
Payload
Reach
Repeatability
Weight
Start programming BORUNTE BRTIRUS3030A
BORUNTE BRTIRUS3030A | SprutCAM X
BORUNTE BRTIRUS3030A description
Watch BORUNTE BRTIRUS3030A in 3D
BORUNTE BRTIRUS3030A applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot BORUNTE BRTIRUS3030A can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Sculpture machining, Multiaxis cutting, Trimming, Deburring.. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how BORUNTE BRTIRUS3030A can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
BORUNTE BRTIRUS3030A applications programmed with SprutCAM X Robot
How to start programming BORUNTE BRTIRUS3030A with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including BORUNTE. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the BORUNTE BRTIRUS3030A, please contact the manufacturer or local supplier.
If you have questions about purchasing the BORUNTE BRTIRUS3030A, please contact the manufacturer or local supplier.
