AUCTECH X16-960
AUCTECH X16-960 specs:
Type Cobot
Brand AUCTECH
Model X16-960
Axes 6
Payload 16 kg
Reach 960 mm
Repeatability 0.03 mm
Weight 37 kg
Start programming AUCTECH X16-960
AUCTECH X16-960 | SprutCAM X
AUCTECH X16-960 description
Watch AUCTECH X16-960 in 3D
AUCTECH X16-960 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot AUCTECH X16-960 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Sculpture machining, Multiaxis cutting, Deburring, Pick and place.. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how AUCTECH X16-960 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
AUCTECH X16-960 applications programmed with SprutCAM X Robot
How to start programming AUCTECH X16-960 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including AUCTECH. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the AUCTECH X16-960, please contact the manufacturer or local supplier.
If you have questions about purchasing the AUCTECH X16-960, please contact the manufacturer or local supplier.
