ABB IRB 6710-210/2.65 MH3
ABB IRB 6710-210/2.65 MH3 specs:
Type Industrial Robot
Brand ABB
Model IRB 6710-210/2.65 MH3
Axes 6
Payload 210 kg
Reach 2650 mm
Repeatability 0.03 mm
Weight 1140 kg
Start programming ABB IRB 6710-210/2.65 MH3
ABB IRB 6710-210/2.65 MH3 | SprutCAM X
ABB IRB 6710-210/2.65 MH3 description
Watch ABB IRB 6710-210/2.65 MH3 in 3D
ABB IRB 6710-210/2.65 MH3 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot ABB IRB 6710-210/2.65 MH3 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Trimming, Deburring, Pick and place.. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how ABB IRB 6710-210/2.65 MH3 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
ABB IRB 6710-210/2.65 MH3 applications programmed with SprutCAM X Robot
How to start programming ABB IRB 6710-210/2.65 MH3 with SprutCAM X Robot
No, we are not in the business of selling robots. If you would like to purchase the ABB IRB 6710-210/2.65 MH3, please contact the manufacturer or local supplier.
If you have questions about purchasing the ABB IRB 6710-210/2.65 MH3, please contact the manufacturer or local supplier.
