BORUNTE BRTIRUS 1820A
BORUNTE BRTIRUS 1820A specs:
Brand BORUNTE
Model BRTIRUS 1820A
Payload 20 kg
Reach 1820 mm
Repeatability ±0.08 mm
Weight 255 kg
Start programming BORUNTE BRTIRUS 1820A
BORUNTE BRTIRUS 1820A | SprutCAM X
BORUNTE BRTIRUS 1820A description
Watch BORUNTE BRTIRUS 1820A in 3D
BORUNTE BRTIRUS 1820A applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot BORUNTE BRTIRUS 1820A can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Sculpture machining, Multiaxis cutting, Robot welding, Pick and place. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how BORUNTE BRTIRUS 1820A can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
BORUNTE BRTIRUS 1820A applications programmed with SprutCAM X Robot
How to start programming BORUNTE BRTIRUS 1820A with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including BORUNTE. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the BORUNTE BRTIRUS 1820A, please contact the manufacturer or local supplier.
If you have questions about purchasing the BORUNTE BRTIRUS 1820A, please contact the manufacturer or local supplier.
