OMRON TM5M-900 SEMI
OMRON TM5M-900 SEMI specs:
| Type | Cobot |
| Brand | OMRON |
| Model | TM5M-900 SEMI |
OMRON TM5M-900 SEMI description
OMRON TM5M-900 SEMI applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot OMRON TM5M-900 SEMI can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Trimming, Deburring, Pick and place, Assembly.. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how OMRON TM5M-900 SEMI can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
OMRON TM5M-900 SEMI applications programmed with SprutCAM X Robot
How to start programming OMRON TM5M-900 SEMI with SprutCAM X Robot
