Comau NJ4-220-2.4
Comau NJ4-220-2.4 specs:
Start programming Comau NJ4-220-2.4
Comau NJ4-220-2.4 | SprutCAM X
Comau NJ4-220-2.4 description
Watch Comau NJ4-220-2.4 in 3D
Comau NJ4-220-2.4 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Heavy-Duty Industrial Robot Comau NJ4-220-2.4 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Continue reading to find out how Comau NJ4-220-2.4 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
Comau NJ4-220-2.4 applications programmed with SprutCAM X Robot
How to start programming Comau NJ4-220-2.4 with SprutCAM X Robot
No, we are not in the business of selling robots. If you would like to purchase the Comau NJ4-220-2.4, please contact the manufacturer or local supplier.
If you have questions about purchasing the Comau NJ4-220-2.4, please contact the manufacturer or local supplier.
