KAWASAKI RS080N-B
KAWASAKI RS080N-B specs:
Brand KAWASAKI
Model RS080N-B
Payload 80 kg
Reach 2100 mm
Repeatability 0.06 mm
Weight 555 kg
Start programming KAWASAKI RS080N-B
KAWASAKI RS080N-B | SprutCAM X
KAWASAKI RS080N-B description
Watch KAWASAKI RS080N-B in 3D
KAWASAKI RS080N-B applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot KAWASAKI RS080N-B can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Machine Tending, Pick and place, Assembly, Robot welding, Trimming. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how KAWASAKI RS080N-B can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
KAWASAKI RS080N-B applications programmed with SprutCAM X Robot
How to start programming KAWASAKI RS080N-B with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including KAWASAKI. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the KAWASAKI RS080N-B, please contact the manufacturer or local supplier.
If you have questions about purchasing the KAWASAKI RS080N-B, please contact the manufacturer or local supplier.
