STEP SD7-900
STEP SD7-900 specs:
Brand STEP
Model SD7-900
Payload 7 kg
Reach 912 mm
Repeatability 0.03 mm
Weight 35 kg
Start programming STEP SD7-900
STEP SD7-900 | SprutCAM X
STEP SD7-900 description
Watch STEP SD7-900 in 3D
STEP SD7-900 applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot STEP SD7-900 can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Trimming, Deburring, Polishing. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how STEP SD7-900 can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
STEP SD7-900 applications programmed with SprutCAM X Robot
How to start programming STEP SD7-900 with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including STEP. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the STEP SD7-900, please contact the manufacturer or local supplier.
If you have questions about purchasing the STEP SD7-900, please contact the manufacturer or local supplier.
