HANS E05L-Pro
HANS E05L-Pro specs:
Brand HANS
Model E05L-Pro
Payload 3.5 kg
Reach 950 mm
Repeatability 0.02 mm
Weight 26 kg
Start programming HANS E05L-Pro
HANS E05L-Pro | SprutCAM X
HANS E05L-Pro description
Watch HANS E05L-Pro in 3D
HANS E05L-Pro applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Cobot HANS E05L-Pro can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Sculpture machining, Multiaxis cutting, Deburring, Pick and place.. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how HANS E05L-Pro can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
HANS E05L-Pro applications programmed with SprutCAM X Robot
How to start programming HANS E05L-Pro with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including HANS. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the HANS E05L-Pro, please contact the manufacturer or local supplier.
If you have questions about purchasing the HANS E05L-Pro, please contact the manufacturer or local supplier.
