MITSUBISHI RV-7FL
MITSUBISHI RV-7FL specs:
Brand MITSUBISHI
Model RV-7FL
Payload 7 kg
Reach 908 mm
Repeatability 0.02 mm
Weight 67 kg
Start programming MITSUBISHI RV-7FL
MITSUBISHI RV-7FL | SprutCAM X
MITSUBISHI RV-7FL description
Watch MITSUBISHI RV-7FL in 3D
MITSUBISHI RV-7FL applications
In general, industrial robots and cobots are versatile and usually don’t have a limitation to a specific application. So, in most cases, Industrial Robot MITSUBISHI RV-7FL can be used for various applications such as pick-and-place, robotic welding, cutting, deburring, polishing, painting, dispensing, additive manufacturing and robot milling.
Its main applications are: Robot milling, Multiaxis cutting, Trimming, Deburring, Robot welding. However, we recommend consulting your robot supplier or the official manufacturer.
Continue reading to find out how MITSUBISHI RV-7FL can be programmed with the all-in-one CAD/CAM/OLP robot programming software SprutCAM X Robot.
MITSUBISHI RV-7FL applications programmed with SprutCAM X Robot
How to start programming MITSUBISHI RV-7FL with SprutCAM X Robot
Yes. SprutCAM X Robot is an equipment agnostic CAD/CAM/OLP platform which supports any known robot brand including MITSUBISHI. You can use components from the equipment library or create your own with our zero-code digital twin creator software MachineMaker.
No, we are not in the business of selling robots. If you would like to purchase the MITSUBISHI RV-7FL, please contact the manufacturer or local supplier.
If you have questions about purchasing the MITSUBISHI RV-7FL, please contact the manufacturer or local supplier.
